Discuss Adding can lights to existing unutilized switch in the UK Electrical Forum area at ElectriciansForums.net
ScottA
I have a question about a 4 line wire ( red, black, white, ground). My room was wired with two switches, one was supposed to work the fan, one the light. Our fan had a remote so they did not hook it up this way. This left the black wire (in the fan) empty. I’d like to add can lights to this room. Could that red wire (and split the neutral) be used to add the can lights and utilize that “extra” switch?
Scott if someone didn’t hook up your black wire on the fan then it can’t run. Take 1 switch and wire it to the black wire on the fan and and take the second switch and wire it to the blue wire in the fan then your fan will be on 1 switch and your light will be on it’s own switch
thanks, I was more wondering if I could utilize that switch and black wire, and tie to the neutral and add can lights
your final answer of "yes" is true.
Now I will add on to that correct answer.
The hot comes into the room, gets split by a switch. then on to the light.
therefore when you move the switch up or down, the light goes off or on.
Now that light, lets say, has another light right next to it. So now we start over.
the hot comes into the room, and feeds two switches. From each switch, they feed each light.Well to do that, I use a cable that has two wires going to the two lights.. One is red, and the other is black, because thats what the cable came with, built in.
Now lets start over again. But instead of two lights, we will make it a SUPER light, that has both lights within it.
Still, I want to switch one, and the other. Because I dont want it to be mega bright like that.
Well that "super light" is your ceiling fan. One wire went to a literal light, and the other went to a fan.
Well now I want to take down the fan, but leave my two wires for two lights.
One wire, I take and use it for some can lights... and the other one, I want to control a disco ball light!
there you have it.
well what about the neutral? that white wire..
Well the white wire, has zero to do with any of this. It has to be sitting up there at any light you have, waiting for you to add a "hot" wire that you brought up from a switch. (once you take a hot, and bring it to a switch, and emerge again, that wire heading up to the light is no longer called a "hot". its called a "switchleg)
If its passing through any box that has a switch, who cares, it will just bypass everything and head on up to the light, waiting for you to marry it with the light and the "switchleg"
I said all this so if things go crazy, or if you wanna do new things, yiou can use this.
Reply to Adding can lights to existing unutilized switch in the UK Electrical Forum area at ElectriciansForums.net
Hi, have an old bathroom fan. Which has two wires the black and red (line and neutral). The fan has no isolator switch and was powered when the...
Hi I am trying to replace my old white light switches for nice chrome ones but the wires are all red but the new switch has only l1 l2 top and...
Hi all, DIY'er here looking for a bit of advice so please go easy on me. In my dining room there is an existing single pendant and i would like...
