Discuss Adding central heating pump to Immersion circuit? in the Australia area at ElectriciansForums.net
L
lawsonium
Hello,
I have a hot water cylinder with an immersion heater which (as far as I can tell without looking further) is on it's own dedicated circuit. I'm not at home right now so can't look up the circuit breaker rating (I'll look this evening).
I have a wood burner with back boiler and intend to use it to heat (indirectly) the water in the cylinder and eventually about 3 or 4 radiators upstairs.
My question is, when I come to installing the radiators is it possible to extend the radial immersion circuit to run the pump?
I would prefer this option rather than running another circuit.
I would appreciate some expert advice. Thank you in advance.
Matt.
Reply to Adding central heating pump to Immersion circuit? in the Australia area at ElectriciansForums.net
Can I supply my central heating (programmer, two port valves and boiler) via a fused spur taken from the immersion heater circuit? They’re...
Hi, I know it's best practice to run an immersion on a dedicated circuit but am I OK with the following A new heat pump is being fitted and it...
We have just completed a self build, and heating system is Air Source Heat Pump, unvented HW cylinder, Buffet Tank, all Vaillant equipment. The...
I recently moved into a flat to find that my top floor main light is wired into central heating circuit, along with bathroom towel rail . As a...
