Discuss Adding loft lighting in the UK Electrical Forum area at ElectriciansForums.net
I've added a junction box with 3 connection blocks to a lighting cable in the loft in order to add a spur for loft lighting. The cable I've broken into operates the landing light and other on the upstairs floor. I've followed 2 wiring diagrams, both of which have identical layouts, but I can't get the loft light to work. Instead, when I switch it on, the landing light comes on instead. I'm using an intermediate switch (live to L1 & neutral to L3) - is that the problem?
From what you describe you don't really have much of an idea what you are doing, and you could end up doing something very unsafe.
Please get a local electrician to look at this simple job for you.
you can't take a feed from an intermediate switch. as abve. get a local spark.
Reply to Adding loft lighting in the UK Electrical Forum area at ElectriciansForums.net
Hi, I’m new to the forum. Thanks for letting me join. Asking for some diy advicd… I’m trying to add a couple more security lights to the existing...
First post so go easy on me. i am a competent DIY’er, just after some advice. Apologise if the terminology isn’t spot on! my house was rewired two...
Hi I want to add a light to my attic. There is a single switch on the landing that I want to change to a double switch and then use it to still...
