- Reaction score
- 143
Hi I am needing to adjust a 1 way switched outside light at a house in a couple of days to switch 2 way possibly with an ip rated switch on the way to the front door as it's only switched 1 way from inside the porch at present. I'm just thinking of instead of an exterior switch of using a Steinel IS140 sensor or similar but haven't used stand alone sensors before. Is there likely to be one which switches via a 3 core between the sensor and inside switch so it can operate 2 way with one end the sensor / PIR and inside the normal switch plate ? Also is it likely still able to be kept on permanently via the old fast switched on/off/on system from switch ? Thanks.
