Discuss Adding second light to existing switch in the DIY Electrical Advice area at ElectriciansForums.net
C
Cox
Hi everyone,
In my garage there has always been one only ceiling light which isn't really adequate when working on projects in the garage. Therefore I'm looking to add an additional light (well 2 really but we'll call it 1 to simplify things).
This first diagram shows the existing wiring (hopefully it is clear enough). Any wires without with only a connection on one end are wires coming from the ring main.
I've thought of 2 methods of adding an additional light, but I'm not sure which will pass certification when I get someone to certify it after. The first method is to simply create a spur off the terminals for the lamp holder as follows:
this seems by far the easiest method, but as I say, I'm not sure about best practices and regulations. The second method would be to add the second light into the ring main and connect a second set of wires from the switch to the new lamp as shown next :
Can anybody tell me which of these is the best method, or suggest another if neither are appropriate?
Many Thanks.
I should point out that even if you have correctly wired this it would not be legal for someone to come in and "certify" the work.
Electrical work should be inspected, tested and an installation certificate issued, by the installer.
However wiring wise so long as you have a normal light switch that can take the additional load of the extra lights and you want all the lights to be switched by the same switch, then connecting as you have indicated in your second diagram, so long as you also remember to extend the earth wire to the new fittings and correctly connect and sleeve it would be a suitable method. Remember that the cable must be at least 1.0mm² and capable of taking the current.
Thanks for the advice, I thought it would be fine based on my calculations, but I wanted to be sure.
Why will it need certifying?
I was under the impression that all electrical installations had to be carried out or approved by a qualified electrician?
I think the point Murdoch is making is not all job's are notifiable. In fact Part p has been watered down so much it is getting hard to justify the cost of being a scheme member.
you should by rights complete a MWC for the job. to do this you need to be "competent". this would also mean owning or borrowing a MFT to complete your test results.
Reply to Adding second light to existing switch in the DIY Electrical Advice area at ElectriciansForums.net
Hi, I have a single light switch, wired like this.. the 2 wires in com, with a always live wire coming to the switch, and then wire going out to...
Hi all, I'm wondering if it's permitted to replace an outside wall light myself if I use the existing wiring from the old light. In theory I just...
Hi I want to add a light to my attic. There is a single switch on the landing that I want to change to a double switch and then use it to still...
i know about the different wiring arrangements for 2 way light switching. i want to connect the permanent live into first switch common, connect...
Hello, I have acquired two FOGLIO wall lamps that I want to convert from wall lights into lamps. I'm not familiar with wall lighting so first I...
