- Reaction score
- 801
i need to add a socket in kitchen for 2300w coffee perc machine. the house is bs 3036 fuse with no rcds, so was thinking just buying a socket with rcd incorparated. there is a socket above cooker hood which is a spur and would be handiest place to take from, as i can just run along the top of units and drill down through cupboard and mount underside of cupboard where it needs to be?
so can i take a spur of a spur with this high load? and if im missing anything, ~??????
im thinking 2.5mm into fused connection, fused at 13A across top of cupboard and down into socket outlet
would i even need to put into fused connection as plug top has 13A fuse or isit to safe guard too much being pluged in.
rawrrarwrrarw yap depscobby dedap thanks yours faithfully
