Discuss Adding to an old mem board? in the UK Electrical Forum area at ElectriciansForums.net
Upfront rcd isn’t ideal, I know.... but it might convince the customer to replace the whole board if he’s given options and explained the pros and cons of each
Am I correct in that if a new shower circuit is installed this would need to be RCD protected as well as the other existing circuits in the bathroom. Supplementary bonding would also need to be installed if not already done so but can be omitted if conditions are met.
I think the Shower DB option is the only realistic route without putting in a new DB for the lot. I would have priced for a 2-way DB personally. I wouldn't entertain using that 3036 DB - depending on shower rating you may even exceed its rating given that 45A I'd already in use. And as mentioned remember the correction factor for rewireable fuses. After you add an RCCB and enclosure you won't save much money on a 2-way DB and it will be much less hassle.
I cant see how it would be far less hassle? I would have to find a route for the tails from the meter box to the new DB next to the existing fuse box, this will not be easy. Granted, it's the better option but I think it will be more 'hassle'.
You could always leave it and walk away. I know I would not touch a job like that personally.
Could I ask why Vortigern?
All circuits in the bathroom are existing. I can't see that I have to offer RCD protection to existing circuits if I am not carrying out any work on them. I'd be happy to hear any opposing thoughts?
With a board like that I imagine the tails and everything in it is somewhat suspect although it is true you did not pan out enough to see the DNO gear. Asbestos in the fuse carriers. The fact that from the sound of what you say the person does not really want to spend a penny more than they have to, to achieve a safer installation. I do not like patch and mend approach or piecemeal additions. And I get the feeling that anything that goes wrong with the rest of the installation will be your fault. My spider sense would make me walk away from it. But what about the 0.725 factor?
It seems HHD has taken the 0.725 factor into account when working out the CCC of the new cable, and it complies.
Those Memera MkI boards were reliable and there must be many still about. But it's unusual to see a 45A Memcert carrier, so if you do end up taking it out, please could we have it for the museum?
I'm also a bit leery of that 30A second from left with the live screw accessible, although this was a remarkably common occurrence with this form of carrier in general, especially the cheap ones. The filler would crack and fall out, or melt and run out if a fuse was subjected to a prolonged low overload for hours on end. Yes, there should be a flash pad made of a popular heat resisting fibrous substance inside.
One final thought, who carries 45A fuse wire these days (20 SWG TC)?
Thanks for the reply.
The 0.725 factor would have been ok, i.e 64A x 0.725 > 45A.
Hoewever, I am moving further and further towards brining new tails in for a separate shower unit therefore avoiding all contact with the mem board.
This is so negative, what should go wrong with the existing installation?
I know that the regs call for all circuits in the bathroom to be RCD protected, however, I do not do this type of work day to day so am interested from those who do in this situation protect the bathroom light with an RCD and yes I can see how there could be a chance of an existing fault or borrowed neutral. Over the years the regs have got us to upgrade things by default. If it was me I would come off the 45A fuse and feed a 2-way C.U. and if the lights had to be on an RCD/RCBO explain this to the customer then the ball is in their court.
I would have loved to have been able to send the 45A fuse carrier to you Lucien after all the good advice you have given me over the years. However, even if it doesn't get used for the new shower I think I had better leave it in place rather than leave a big gap :).
If you come off the 45a fuse how will you deal with asbestos. That is a pita already. Will the customer pay for testing/removal. Will you remove the fuse. What are the chances the fuses are wired in anything but the correct fuse wire? I will be interested to see how you progress with the job and customer.
This is so negative
What can you mean? Do you mean what you are saying or me?
I was referring to the impression of the above you gave me which is unusual I am sure that happyhippydad is going to charge a fair price but the customer has a choice he gets the job done correctly or not and if it costs extra if the lighting has to be sorted or supplementary bonding needs doing it is up to them to accept the cost of doing it properly. I seemed you were finding a reason why not to do the job as to how to get over the issue.
They keep banging on about how expensive a funeral is on the telly.
Let him know a new all singing CU is much cheaper.
Unless he wants to harrass his neighbour with parsnips.
Reply to Adding to an old mem board? in the UK Electrical Forum area at ElectriciansForums.net
Hi all, I am looking for some advice regarding old rewireable (3036) fuse boards in regards to additions and alterations. I am an electrician and...
4K
Bit of a long shot on here but does anyone have a circuit diagram for a Chavin Arnoux CA 6545 5kV tester? I've copied my post on EEVBLOG forum...
I have a box powering three 3-phase motors off of one 240V single phase line, NEMA 10-30. In the picture you can see a wiring diagram. The...
Hi, I've recently had my broken oven replaced in my flat and I paid for delivery and installation. It was hardwired through an unswitched plate...
Morning All I recently completed my first re wire and board change, (with help from the owner who is a gas fitter and plumper, who works with my...
