Discuss Additional shower in the Industrial Electricians' Talk area at ElectriciansForums.net
B
bob67
Hi,
Could someone please advise:
I already have a shower in the en suite which goes direct to the consumer unit. I now want to fit an additional 9.5kw shower in the bathroom which is next to the ensuite. Do I have to run a seperate cable to an addiotional point on the consumer unit or can I join the cable in the loft via a onnection box to the existing shower hence only having one cable going to the consumer? A pologies in advance for the ignorance
Hi mate,from the sounds it definitely not a job you should be doing your self (no offence)
your new shower will need to be run direct from the fuse board in 10mm t+e..... but you will also have a problem of overloading the main fuse if both showers are on at the same time .... you can get a dedicated fuse board that will only allow 1 shower to run at a time .... Get a good spark in and am sure he,ll sort a good solution.
Remove supply cable from consumer unit run it through an enclosure with a 45amp
revesing contactor in it then run a cable from each contactor to each shower switch . you will then have to only install a short length of new cable to the second swower and you have interlocking between contactors.
Reply to Additional shower in the Industrial Electricians' Talk area at ElectriciansForums.net
Hi, I am changing the electric shower in a bathroom refurbishment (my own) and just wanted to ask about the mcb rating. The existing shower was...
Hi guys. I was wondering what size cable and braker I'd need for an electric shower. Just out of intrest am I close in guessing as follows: The...
Hi, I have a client with a small caravan site, approx 5 hookups. His old toilet block was nothing much more than an old shed. He's now 'upgraded'...
Hi all. Sort of an interesting one. I had a call from a client to say she is getting a shock when using the shower. I told her not to use it and...
Hi, I`m looking for an advice. I have an electric shower that I`m not using due to boiler changed to combi and added shower over bath feed by a...
