Rocboni
- Reaction score
- 145
Hi,
I’ve been asked to look at a ADE optima compact plus as the zone 1 light is activating and it beeps everytime the PIR as activated I.e when someone walks Infront of it even when the system isn’t armed? You can press reset and the light goes off but as soon as it activates again it comes on.
Has anyone got experience with these panels and can indicate the fault, that alarm seems to be able to be set.
The engineers code is not known! I’ve also got a new battery to fit in it if I can get into it without the tamper setting the alarm off
This is the manual, seems to be different to more modern versions
http://www.moretonalarms.com/pdf_engineer_manuals/ADE_Optima_Compact.pdf
