R
Roger
Ok lets pick you brains on this one.
Need to run a electric shower upstairs,would use 10mm T&E.Its a 3 bed semi and the customer suggested lifting a few boards and running down the cavity ! it has poly balls insulation which i understand will create problems with cables and cause them to crack over a period of time.
The consumer unit is sitted more than 3 meters away from the meter and incoming supply.This is in a service box on the outside of the property.Current CU is fully populated so I thought about splitting meter tails in service box ,putting a RCD/RCCB unit in and running cable in conduit up outside of building.Drill through outside wall and then just feed under floor boards.
Is this ok ? any thoughts ? suggestions ?
The whole house is finished to a high standard with built in units all over the place and every bit of space is full.
I gave a ball part figure which I thought was high so hoping they would say no,but they said yes !!!!
Its a pain of a job and i do not really need it at the moment so hopefully I will just keep saying I am to busy and he will just go away.
