J
Jason63
I need advice in regards to connections to an electric boiler with two immersion heaters. At present, there is an on peak switch connected to one immersion and off peak switch connected to the second immersion. The first immersion is not working anymore. I want to connect the working immersion heater such that it works off peak and on peak using one switch. Should I use a double pole changeover switch?
