Discuss Advice needed please for replacement inverter in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
I have 16 245w (declared capacity 3.84kW) panels on a south facing unshaded roof on the south coast of England producing around 4200 kW-h a year for the last 7.5 years; I have had two inverters fail in that time, the first replaced under warranty (both Mastervolt SunMaster). I have no schematic but all 16 panels are on the same string. Single panel voltage at 245w maximum listed at 30.67 PMax and 37.77 open circuit. I'm not an electrician but understand the high total DC output of the panels on the one string requires an inverter capable of taking the high load. Any recommendations - one with a 10 year warranty/option preferred? The inverter is in the loft and cannot be moved. Many thanks.
Reply to Advice needed please for replacement inverter in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Hello there I have just installed a new Solis S6-GR1P3.6K-M-DC Inverter - this replaced a 10 year old+ Sungrow inverter that failed/out of...
My system has had an intermittent problem for the last few months. The inverter has occasionally been reporting PV Voltage Too High, then it would...
5K
Hello All, I'm seeking some advice about a solar PV system we had installed in November 2014 please. After 18 months, we seem to be consistently...
6K
crossplot
C
My 3 year old install for a while has been giving me issue with nuisance tripping the 30ma RCD in a 17a Split board I had originally thought the...
Markos
M
F
A few weeks ago, I had my solar panels remove from my roof and then replaced. Sadly, on removal, one panel was warped and on letting the fixing...
