M
MKSparks
I am currently doing some work in a school and have two socket outlets that I need to remove as the wall they were originally on has been removed as part of the building works.
The sockets are ran in a steel conduit fed up from under the floor, I have no problem chasing out the floor to install a conduit box of some kind, however I am trying to determine the best way to terminate the existing conduit in order to maintain the CPC as the ring main has no earth conductor.
The two socket outlets in question are approximately 3 meters apart so I could channel out the floor, remove the section between them entirely and try to install a new section with a through box at each end to reconnect the circuit, the problem I've got is mainly cutting a thread on the old conduit, Is there any way to terminate without threading? a push-fit style connection that would maintain earth continuity? open to any suggestions...
