Discuss Advice on basic alarm. in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
Hi. I've been asked to fit an alarm that will give audible/visual warning if an infra red beam is broken between 2 points.
It will be in a warehouse environment fitted indoors and I plan to fit them about 5m high to steel uprights about 15m apart.
This is a standalone alarm only not part of anything else.
Just wondering what products are out there to achieve this as its not something I'd normally do.
Thanks.
use a 12V alarm PSU. power the detectors direct. use the detector alarm output to trigger a timer relay . r
not offhand. basically you need a dual beam IR sender and receiver with a range greater than the distance apart that you fit them. something like :
Thanks. I'll look into it.
Reply to Advice on basic alarm. in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
J
Hi all, first of all sorry if this thread is not in the correct section...wasn't sure? Ok so basically its not a problem, just wanted to hear...
8K
E
I think I've Posted this before, but I've just updated it. Some of the sparks where I work still get a little confused of what the different areas...
77K
Not done industrial installation before and will be looking at a job in an automotive workshop on Tuesday needing (probably) about 10 metres of...
9K
F
Hello everyone I have recently converted my sisters old open vented semi gravity central heating system to a sealed fully pumped Yplan with...
27K
lee mcgregor
L
