• If you have electrical work available, then you are in the correct forum.
    Post details of the position you have on offer in this forum. Domestic / homeowners are also welcome to post electrical work they have available on their property. Or you're welcome to seach for a Local Electrician in our directory.
Discuss Advice on Bathroom Extractor - Potential Job in the Electricians Jobs area at ElectriciansForums.net
This electrician job is going for grabs, please don't post contact details in this area of the forum. Use the forum messaging system instead.
Hi there,
Thought I'd post this here before I go ahead trying to hire someone, when it's something I can do myself. My bathroom extractor has packed up (seemingly). Very limited knowledge of electronics so don't want to start taking things apart. I can't tell if this piece of material is jammed in the fan in the attic and don't want to remove it and potentially start breaking things. Cleaned out the two vents in both bathrooms and both were well clogged with dust. Could someone advise me on how to proceed?
Kind regards,
R W-M
isolate supply. unclip ducting from fan, if you can access the fan blades see if they're free ( using a thin driver). if they are free, restore power and switch fan on, see if it runs or not.
Strictly speaking, it's bathroom work so you need a qualified sparky. Either way, make sure it has a 3 pole isolation switch. If doesn't, then you will need a sparky to isolate it before you go poking your fingers in it.
could you let us know if the insulated ducting is part of the fan make up or if that is doing something else. wherever possible I try & use rigid ducting even if it means covering in insulation in cold space (loft), flexible ducting is ok on small runs but you mostly always get that type of dust & mould issues from having it installed. I personally would not bother cleaning out the white flexible duct I would replace with a new bit unless can be replaced with rigid.
Reply to Advice on Bathroom Extractor - Potential Job in the Electricians Jobs area at ElectriciansForums.net
Whats everyone's take on this, turned up today to start a re-wire and yet again there wasn't any toilet on the job so we ring the builder and he...
6K
Hello everyone, I hope nobody minds that my first post is a question. We have a bit of a situation brewing at home with regards to our new...
4K
I'm having an extension built and the builder leading the project has said that the electrician will be over in about 4-6 weeks to start his works...
Not looking for a job - well I am and would welcome any offers, but that's not the purpose of this thread. What I need at the moment is advice...
