Discuss Advice on best method to run a cable for power in Garden in the UK Electrical Forum area at ElectriciansForums.net
RDB85
Trainee
I’m looking for the best method to run a cable from the CCU from the Garage to the 30ma RCD in the Garden.
I am going to order some HiTuff rather than SWA as I can’t get the paving slabs and stones up. Also I’m not sure about drilling into the concrete posts. I have attached some photos for reference.
39187536-0C95-4338-81B9-5C7B048D4B10.jpeg4E95844B-6C5F-4F2A-835F-98E5ED19D726.jpegEBD72D5A-3A7C-4622-817B-19EB5AD14A69.jpeg837B921D-9A48-4A73-85E3-E52390C6E700.jpeg070DDA2E-BD40-4E12-A270-4F17FCB518B7.jpeg3B99A865-A0F1-4FD8-8C63-427BADC0B178.jpeg39187536-0C95-4338-81B9-5C7B048D4B10.jpeg4E95844B-6C5F-4F2A-835F-98E5ED19D726.jpegEBD72D5A-3A7C-4622-817B-19EB5AD14A69.jpeg070DDA2E-BD40-4E12-A270-4F17FCB518B7.jpeg3B99A865-A0F1-4FD8-8C63-427BADC0B178.jpeg
View attachment 60798View attachment 60799View attachment 60800View attachment 60801View attachment 60802View attachment 60803View attachment 60798View attachment 60799View attachment 60800View attachment 60802View attachment 60803
The correct size of cable cleats spacing as per BS 7671
You don't have to bury SWA!
Is the supply already on a RCD? If not you would be well advised to go for SWA and run it as for the hituff stuff. You need a proper gland to connect the armor to earth at the supply end, but if you get 3-core SWA then you can make use of a simple plastic gland at the far end as one core provides the CPC for the load.
cleat SWA to the one of the horizontal timbers on the fence.
I was looking at conduit but I would have to fix the conduit and saddles to the facias due to the door on the garage. Then fixing along the fence as suggested.
Can anyone recommend where best to buy conduit and fixing from. As I’ve seen mixed reviews from Screwfix and Toolstation. Also seen someone on another forum say that you can use a heat gun to do bends etc.
Any Electrical wholesaler will stock OVC conduit, and you do not need a heat gun to bend it a bending spring of the correct size will suffice.
My uncle has said that he also has some Arctic Flex in both Blue and Yellow. The blue is 1.5mm and the yellow 2.5mm would that be okay to use? As I’ve bought 20mm Conduit. He did say that the 2.5mm FP200 would be fine as it’s current rating is 24a and is protected by a 32a RCD. Just wondering would the Arctic Flex be any better?
Reply to Advice on best method to run a cable for power in Garden in the UK Electrical Forum area at ElectriciansForums.net
Hi, I'm going to be wiring up my garden office with power and ethernet underground and I need advice on the best way to run the cables as I have...
Hi I've got an new outbuilding that needs power run out to it, the building is very close to the house and the original plan was to run an...
Hi Gents, I am thinking about running some cables in the garden. The idea is to electrify the garden. My idea is to run some electrical cables...
Hi, I’m new to the forum and am seeking some advice please. I’ve picked up a job that another electrician has abandoned, the job is to...
Domestic property Supply number 1 6 flood lights 4x400watt= 1600 watts 250meters from board to closets corner of tennis courts Tennis court...
