Discuss Advice on Biomass.... in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
B
Berneray
Morning guys....
Looking for some help. We're about to start an install on the stables of a large old country house. As part of the project they need to upgrade their old oil fired boiler. Doing that plus the 10kwp pv system will get them into Band D. They current need three fills of the tank a year and I'm just wondering if biomass might be an option.
Although we are Gas Safe installers we have never done a biomass install.....Is it feasible to install a biomass in the time left for FIT....I know biomass gets RHI not FIT but the Band D depends on installing a new boiler....
Has anyone any experience in biomass and the £950 grant. What would be best advice for our customer......Large listed house, stone built walls, 15 bedrooms, original single glazed sash windows sitting in 100 acres of ground....A new oil fired boiler......or a new biomass one....
Any thoughts from you guys great fully accepted as usual.....
biomass could defo be an option, If there is a business run from the property it could get the commercial RHI payment 8.1 p unit pay back typical for commercial installs is 2-4 years depending on how much additional work for the boliers were required.
i am currently working on a project for a collage where the figure drops to 4p unit there pay back equates to 1.29 million pounds over the term. If the Bolier is under 45kw it must be installed under the MCs scheme to get the RHI payment remember if its domestic the rhi payment doesnt come into play next summer and we dont know the figures yet pm if you whish.
regards
Wiggly
- - - Updated - - -
Also if stables are still using horses the stable waste can be used as fuel for the boilers.
regards
wiggly
would depend where the boiler is sited, the system it's on (sealed, O/V) the fuel store position if using pellet or chip etc.If it's a listed building then you may require planning etc
It wouldn't be a case of 1 in one out. Not sure what appliance would be suitable for burning hay though.
Reckon you'd be hard pushed to beat the FIT cut. What about chucking in a cheap oil condensing boiler and look at upgrading to biomass after?
Just had a look at their website, interesting idea, no mention of efficiencies or MCS approval though. They are also not permitted in smoke free zone which would indicate a certain amount of incomplete combustion/lower efficiency/higher maintenance.
Not sure I like the idea of an incinerator in a domestic setting!
Reply to Advice on Biomass.... in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Hi All, We have an old Country villa in Spain. The housing electrics were not good so the house recently has been completely re-wired to a good...
Hi all. Have an issue i'd love some advice on if anyone would be so kind. Will try to be brief. Thank you!! So, have an intermittent RCD trip at...
Hello all Looking for some electrical advice if possible. We had a boiler and complete new central heating system installed in our house 3 years...
Hi, I have received conflicting advice about Main Isolator Switches and would appreciate forum member's help to plan a way ahead. Looking to the...
Deleted member 155212
Hi all, New ill ( not used yet) of 7.5kw EV charge point. New...
