Discuss Advice on fireproofing in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
dp6ai
Hi,
My architect has ben told the following by building control:
"also confirmed that any light penetrations for recessed light fittings will require fire resistant hoods to prevent fire passing through the light fittings into the gallery floor void over"
In that space i have a number of standard down lighters, i'm intending to use these:
Robus® Fixed Round Mains Voltage Fire Rated Downlight White 240V | NoLinkingToThis
some bathroom down lighters, using these:
Robus® Fixed Round Mains Voltage Fire Rated Downlight White IP65 240V | NoLinkingToThis
I also have a standard pendant in one of the bedrooms, which i need to fireproof but none of the products i've seen seem to be fire resistant.
Can some one let me know what i should be using for this and also if the above products seem ok?
thanks
DP
Both of the downlights are fire rated, so there'll be no problem with those. If the hole for cables into the pendant fitting is less than 30mm there should be no problem with that either.
DP
This statement is really saying that the fire rating of the ceiling must be maintained. The use of the words fire resistant is erroneous since whilst the fire hoods may be somewhat fire resistant the main function is to either swell up and seal a penetration or react to heat in such a way as to prevent the further passage of fire through a ceiling penetration generally by forming a non combustible smothering mass.
A separation between a ceiling and a gallery void would normally (but do check the regulations) be a 30 min fire rated ceiling. i.e it must prevent the transfer of fire from the room below to the void for 30 minutes.
Fire rated downlights are rated at a minimum of 30 min and can be 60 or 90 mins rated. So the ones you specify should be fine for the purpose.
If you have a pendant where the cable passes through the ceiling this will not normally affect the integrity of a 30 in fire rated ceiling, however if it is required to seal this penetration then you can do this with an intumescent sealant, this will swell and block the penetration in case of fire. Then fit the pendant on top.
Reply to Advice on fireproofing in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
Electrical2Go - Mega Downlight Deal - Don't miss out! Taking place from August 18th to 20th, we're offering an incredible promotion for...
Hi, Having a new kitchen fitted and was hoping for some advice please. How many LED downlights do I need? Will likely be using these linked below...
4K
Hello, I wish to purchase some Downlights to replace some halogen spotlights in my bathroom. Currently the existing spotlights are powered through...
4K
Hi there, I'm a competent DIYer that has done lots of with lighting over the years but have just moved into a house packed full of mr16 halogens...
9K
Hi, First time posting on here so apologies if I'm missing any basic information, but hopefully someone can help me as an amateur DIY-er and...
5K
