Discuss Advice on rewire method in the UK Electrical Forum area at ElectriciansForums.net
I have see these in the wholesalers, not had to use them ny self but they look a handy bit of kit .
https://www.amazon.co.uk/Silverline...39&hvtargid=pla-421739994949&psc=1&th=1&psc=1
If you are going for one of these don't get the silverline cheapy one. I did and the hole size was not a snug fit for the plug, the rebate being too wide and too deep. I took mine back.
The Armeg sets are spot on but a bit pricey. The newer cutters have a cobalt mix to the cutter for a longer life. Much better fit.
They do two sizes, I went for the larger one to accommodate my fat hands.
How much would you say it would cost for a 3 bed property? Never used them, always seemed to priceyin the wholesalers
apart from the damage you'll inevitably do to the flooring, you'll find wet-pants has run his spaghetti tight up to the underside of the floor and it could route anywhere. you'll end up with broken, soggy wet chipboard,and the ceilings below will probably need replacing also. only time i've gone in through that type of floor, I've got the customer to cut it, and take all the responsibility. ended up it cost him another £200 to repair the floor.
Or work harder, save your money and stay away from Barrat Houses.........
Round here it's the new build lego boxes that are the most pricey
Depends if the joists are open or closed. If open I would consider this as a method, if the joists need drilling I would consider other methods. I use this tool usually for small jobs where only a few holes are required.
I think Tel's method of not rewiring is the best one to be perfectly honest. Asking for a possible nightmare.
Another vote for having some of the ceiling down, rather than trying to remove the chipboard (or whatever it is) flooring. The plasterboard will come down easier than trying to get the floor up.
Bet the ceiling is artex anyway. Easier to get your pipework in (plastic as well). Quick patch up, and get the ceiling skimmed. Sometimes this type of flooring is part of the structure of flooring joists, you never get it back the same.
Reply to Advice on rewire method in the UK Electrical Forum area at ElectriciansForums.net
Good day. First time poster. We recently had an electrician perform the EICR, as this is a newly purchased property I thought'd I would have the...
I've recently has an EICR (report attached) carried out on my two bed flat because I need to rent it out for a year. The electrician has come back...
Hi. I'm in the process of getting my qualifications and am taking on some small jobs for family to try and get some experience in. Today I was...
Hi What would be your thoughts on this one? I bought this property last year, it was rented since 2005. EICR from 2016 states "wiring in fairly...
