Discuss Advice on Voltage Testers please. in the Electrical Tools and Products area at ElectriciansForums.net
or one of these like wot i have.
i also got this.:
and should either of these fail, there's always a wet finger.
I have this one it comes in its own case and the proving unit is easily used through the test probe holes in the bag.
Agree best one I ever had no gimmicks, does what it says on the box good bit of kit. expensive but worth it, in my opinion.
Never used a proving unit ever until recently
I tend to carry a Martindale AVI (after my Steinel broke) also have a clamp meter , multimeter and a Drummond all in the same bag, but only use the AVI's for checking voltage is present etc
One thing that annoys me is most makes the probes are quite chunky and some isolators don't have holes big enough to make contact
Previously always used known supply, seemed like a large outlay for something rarely needed for the type of work I used to do as there was always a socket or something that could be utilised
However moved into more industrial work a few years ago and had several occasions recently on sites where using a known supply wasn't allowed as it usually meant opening a panel etc and a proving unit was needed ,
Daft rules I had to prove dead then lock off etc only to be turning panel back on after dead testing to faultfind components which was allowed !
Spent 30 mins looking around at various sites and saw a used RS branded proving unit on eBay
I bid a fiver and won it, so with postage came to just under 8 quid , new battery fitted worked fine and probably the best bargain I've ever had tool wise!
I've had my fluke T5 for around 7 years at a guess. Works a treat still. Continuity readings start off a little high when the batts are low, but then I don't use it to get accurate readings as such. The croc clips are a good addition to have.
My only gripes would be that you can't zero the leads, and the annoying curved back which stops it from sitting still when using both probes.
I saw the guy an Indian electrician bring it when he came to turn power on to our panels on a job
He was a bit bemused that I wanted a photo of it as it's either one of these or a neon screwdriver for them
He asked what we used
So I showed him the Steinel probes I had then
He looked at them and said "How is it working Sir"?
Gave him a quick demo and for the next few days he kept bringing his mates round for a look and I had to repeat the demo and let them all have a go!
we have 6 Chihuahuas. ( 9 with the new litter, born last week).each will jump 3 ft. on 230V, 5ft on415V.
When I first started my apprenticeship, my old chief did actually stick his fingers into light sockets - "yerp, she's still running..."
I found this in a box in the shed the other day.
Still working. The "light vibration" referred to is quite fun....
Reply to Advice on Voltage Testers please. in the Electrical Tools and Products area at ElectriciansForums.net
i need to purchase a voltage proving unit - i have seen Megger MPU690, Martindale PD690, and Socket and See SP400, and Fluke but difficult to...
Hi all, Firstly I am new to the forum, so will start by saying hi. I work as an electricians mate, and am joining the forum to gain experience...
Electrical2Go - Megger MFT Deals! Upgrade your toolkit with our exclusive offer! Purchase any of the Megger advanced multifunction testers –...
After some scoundrels robbed all my stuff I have had to get a new voltage tester. Two in fact. A fluke t150 and a a fluke t110. But unlike the...
At work we've got an 8 panel single string set up, going into a 3000w inverter via a double pole DC isolator. The AC goes supply > isolator >...
