special_dx
Hi All
I'm a newbie to wiring and this forum, but I am reasonably technically minded and cautious. I will try to keep this simple, but I am behind the curve on requirements and terminology and I would like advice on what I need to do regarding regulations and my expectations of what I can actually instal.
My plan is to assemble the materials I need to wire my garage and get a local part P electrician to do the job with my help as labour as I am on a tight budget; he has already agreed and given me some basic advice, but I wanted some collective knowledge and guidance on my ideas.
The structure:-
-New concrete sectional 18'3" by 8'6" Lidget pent roof garage with steel doors next to boundary.
-I have insulated the ceiling to stop condensation using 30mm polystyrene with 1/4" ply and treated lath frame and painted the floor with a polyurethane product.
-Doors well sealed against moisture ingress and wall sections sealed with mastik at the slab.
-I have put some freestanding kitchen units and work top in half of garage as work area for mechanical fitting and power tools (domestic/hobby use only), the other half houses my motorbikes.
Advice needed:-
-The consumer unit in the house is full, it was installed less than 18 months old as part of a full rewire when we bought the property; can I get a second smaller CU installed to feed the garage via 10-15 feet of suitable SWA cable and what will it need in terms of switches/breakers etc?
- I have been given two brand new CUs, one is an empty GE 6-way metal unit to IP41 (100A main switch fitted), the other is a Protek IP65 Plastic 100A 4-way unit with a main switch and 40A RCBO pre-installed. I also have a small selection of new and used MCBs of 6A and 32A type B that I was given at the same time. Is any of the equipment I have suitable to use if one is installed in the house and the other in the garage and can the IP41 unit be used in a garage as it is larger?
-My mains supply comes into the house from an underground cable of 1960s vintage, do I need to be aware of any possible issues to check.
-Should I consider seperating earth for the garage from that in the house.
- I would like to instal one twin tube 8' flourescent (switched at two doors), 1 or 2 150W security lights, 3 double metalclad sockets, a single metalclad socket, a 13 amp fused spur for a small lathe and a suitable spur for a welder (30A?). Is this reasonably acheivable or should I aim for a lesser setup?
Any assistance will be very gratefully received, but it needs to be in plain language or include some links to help me decifer the terms used.
Matt in South Cheshire
The structure:-
Advice needed:-
