Discuss Advice please: Programmable Room Thermostat in the The Welcome Forum area at ElectriciansForums.net
dipsb_13
Hi All
Was wondering if anybody can help me out...
I am trying to replace a standard Honeywell thermostat with a Sunvic Programmable Room Thermostat http://www.sunvic.co.uk/tlx6501.htm
My current Honeywell thermostat (not programmable) has 4 wires coming from it
* Earth
* Neutral
* Live
* Additional - this i have been told is a link (smaller red wire)
The new Sunvic programmable thermostat only has 3 places for wires to go in the following points
* NO
* COM
* NC
Please can someone tell me what goes where as I am confused?
Thanks in advance
what do you mean a "smaller red wire"?? you mean it's shorter than the others or smaller in diameter? is it not just 3 core & E?? earth, brown (red), black (yellow), grey (blue)??
Welcome to the forum. :) Be sure to follow all the regs! I'm not a sparky so I'll stay out of this one.
Hi All
Grae79 thanks for your response, I have attached the photo below of the wiring going to my current Honeywell room thermostat.
This is the programmabvle theremostat I have got Sunvic Controls Limited
Really appreciate your help.
first thing's first, make sure the exisiting stat's properly isolated before you start!! if you don't know how to do this then call in a professional, pls!!
if there's no earth on the new stat then terminate it in a conn. block...same with the neutral (blue)...seperate conn. blocks, obviously. then you want your permanent live (red) to the COM on new stat..and your switched live (yellow w. red sleeve) to N/O on the new stat. that should be that. :)
FANTASTIC thanks!!
Do you know where the shorter red wire would go? - the one thats going to point '1' in the image on the previous message.
Thanks again
Reply to Advice please: Programmable Room Thermostat in the The Welcome Forum area at ElectriciansForums.net
I have a Firebird oil boiler that is controlled by a Honeywell timer (no thermostat) that has channels for hot water and central heating...
I am trying to find a replacement programmable thermostat to retrofit onto an existing installation, as the existing one has got a blank screen...
Hello, I have a regular boiler doing room heating only, with a Drayton programmer (for time) + a Drayton dial stat (for temp). I've bought a...
Hi, I want to either replace or add a thermostat to my Heating Programmer which only has basic functions of On/Off, Timer and Boost.. Can a...
Hello all. So I am sure the expertise on this forum will be able to decode this very easily. But it has completely baffled me. I'm in training so...
