- Reaction score
- 2
I am refurbishing a house i bought last year & looking for thoughts on whether the following existing wiring is right/ safe. I dont think it is but would like to check as it looks like spurs of a spur to me. The CU was just replaced by local electrical contractor & all circuits are he says, showing ok on the test certificate he gave me.
A single 2.5mm t&e coming down the wall from the garage loft is feeding a double socket (A) in the utility room which backs onto the rear garage wall. This in turn is feeding a second double socket also in the utiity room. (B). Socket A also feeds a double socket behind the wall its on in the garage (C) and then from this there is a single feed to a switched fused connection unit that supplies the CH boiler in the garage.
I would have expected the utility room sockets to be on a ring final circuit & also the garage socket as its right behind socket A.
Tia
Tia
