Discuss Advice with changing a ceiling light pls in the DIY Electrical Advice area at ElectriciansForums.net
Craig1980
Hey - I’m about to attempt changing a ceiling light however a bit apprehensive with removing the old fitting until I fully understand the cables and connections required.
I have attached a few pics, would someone be able to run me through the requirements to connect the new fitting please.
Trying to research online however still not fully sure yet.
Any help appreciated.
Craig
I assume there is a block connector with three red wires not directly connected to the existing light fitting.
I’m unsure, not seen this. Why?
can I take the 3 blue/black grouped wires out of the existing fitting and simply insert them into the relevant L/N spaces on the new one. It came with a spare terminal block connector which I assume is for connecting the loop. I’m just unsure how to tell which is L, N and loop on the existing fitting.
The three red wires if present will be the loop. Are they shoved up into the ceiling void.
Reply to Advice with changing a ceiling light pls in the DIY Electrical Advice area at ElectriciansForums.net
Hello, Looking for DIY electrical advice. I have 7 x spots, and each are fitted with 1 x T&E connector block fitting [see photo]. In the past...
Hey - so here is a connundrum! I installed a 5-bulb ceiling light (see pic) but when I put the 4w LED bulbs in, they start making a very rapid...
Hi everyone, I really hope someone will be able to help. So last night I tried to change 2 ceiling rose / pendant lights at my mother in laws...
Hello all. So I am sure the expertise on this forum will be able to decode this very easily. But it has completely baffled me. I'm in training so...
