Discuss Advise needed - Wiring Up Room Thermostat in the DIY Electrical Advice area at ElectriciansForums.net
Well.... without wishing to ask an awkward question, have you read the instructions in the box for the new unit or consulted the manufacturers website?
Is it a combi boiler you are wiring this new one into?
If so and I may be wrong but I'd need to have another wire at stat position. Live/neutral. Then from the "link" in the boiler, a flex/cable going to common (brown for example) then Blue to no contacts. It may be possible to link live to common depending if the boiler is 230v switched..... But I'd check with manufacturer as new controller may not take 230v switching...
I'm assuming you're not an electrician Andy so I've moved this to the DIY section for you.
Hehe thanks for reply , yes checked there website and instructions but wanted to be sure that I got this correct before wiring up, I post a pic of what boiler we have if that will help, and I contact manufacturer see if they can help. Thanks
Reply to Advise needed - Wiring Up Room Thermostat in the DIY Electrical Advice area at ElectriciansForums.net
Hi there, We have recently replaced our central heating programmer with a Honeywell ST9400C. We now want to replace our old wireless room...
Hi all looking for some helpful advice I'm an Aussie so go easy on me, I have a good mechanical engineering head but first time plumbing and...
Hello, I have a regular boiler doing room heating only, with a Drayton programmer (for time) + a Drayton dial stat (for temp). I've bought a...
Hi folks, I'd like to get my Nest thermostat up and running with the gas combi boiler (Worcester Greenstar HIghflow 440 Standalone). FYI - I...
I would like to replace my ancient Honeywell mechanical thermostat with a Honeywell T3R PROGRAMMABLE THERMOSTAT I have three wires in the old...
