Discuss After having an electrical rewire - certificates? in the UK Electrical Forum area at ElectriciansForums.net
H
Herbie
Hi,
After having a partial electrical rewire of a domestic property and existing electrical installation tested which certificates should I receive from the electrician and should I receive something from the council, also are they uploaded somewhere so they can be downloaded in the future?
Thanks in advance for replies :)
Electrical installation certificate with appropriate schedule of inspections and test results.
If you used an electrician who is part of a competent persons scheme then Part P notification should be done for you with a reference number. If not then you need to notify building control.
Depends on the extent of the new wiring, if new circuits have not been put in place this isn't necessarily notifiable under Part P.
Would that be where is says "Certificate reference"?
If the certificate is lost how is a replacement obtained?
There should be a Part P reference as well as a certificate reference/serial number.
If you lose a certificate then contact the installation company for a replacement, normally a small admin fee could be incurred.
Could the op give a bit more information
Do any of the new or replacement circuits go from the fuseboard, and has a new fuseboard been fitted?
As said, the certificate from the sparks. A compliance certificate via his/her scheme in the post, addressed to the 'occupier' of said property, if the sparks is in a scheme?
Normally that sort of info is agreed or stipulated in the quotation.
In my understanding of the definition of rewire, I'm referring to the broadest terms.
The Domestic Electrical Certificate I was given last week is 6 pages, there is no mention of Part P and nothing has arrived in the post.
A new consumer board was installed.
As far as I'm aware that is work that should be notified (I'm not from England so not sure). If you loose the certificate you generally can get another one from the electrician but will have to pay for it
Neighbour has just received her building cert for a garage conversion that was completed two years ago...
The 6 pages you've received... Are they hand written? Could be an indication that he has duped it and sent you a copy but not yet filed it with niceic or equiv. Or could also mean he printed a load of certs off the internet and hands them out without filing them. Who knows...
Your gonna give the OP nightmares; often there is a more simple less devious reason.
Reply to After having an electrical rewire - certificates? in the UK Electrical Forum area at ElectriciansForums.net
Hi Everyone, This is my last question/post for tonight, promise. Please can I ask for a little advice on certificates as I am now questioning...
I have been asked to change cu from old fuse board which has 6 fuses. Only 4 fuses are used. The first fuse feeds cooker circuit. This is not used...
Good day. First time poster. We recently had an electrician perform the EICR, as this is a newly purchased property I thought'd I would have the...
Hi. A few years ago we had a full house rewiring done by an electrician who issued a certificate for the work. He also left in the consumer unit...
Hi What would be your thoughts on this one? I bought this property last year, it was rented since 2005. EICR from 2016 states "wiring in fairly...
