Discuss aico optical smoke alarms, sensitivity, and hairdressers in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
SPARTYKUS
Hi
fitted 3 radio linked smokes a few years back, one ionising in a communal hallway above two shops (these got radio linked, mains free optical AICO's, the expensive ones - mains free as wiring was shot at time so refused to connect anything to it!).
Only option at time was the optical version.
It has worked well for a year or so but seems to have gone awol - in particular the one in the hairdresser.
What are peoples thoughts / experiences on smoke alarms in this environment? I knew at the time of the extra sensitivity of the optical alarm. I'm suspecting the thing is now full of hairspray and 'juiced' (no point hoovering it). It just goes off constantly.
Btw (*edit*) before any 'wit' asks, there is not a fire in the hairdressers.
As an ironic twist shortly after fitting them the property was flooded and partially rewired / new boards etc so is up to scratch now.
Would you -
1. Fit another ionising smoke alarm (radio linked to others, but mains powered now, to lights - all surface trunked anyway)
2. Fit a heat alarm. Would this help with the clouds of hairspray, etc that appear to have clogged the existing one up.
Cheers in advance for any thoughts.
S.
Reply to aico optical smoke alarms, sensitivity, and hairdressers in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
Here we go again, another job that has had a council inspection, different council to last time but still perplexing. The problem with these jobs...
Not come across this before, so would like some help, please. I went to install smokes and heat alarm (to new Scottish regs) in a fairly modern...
Hi all, I'm working in a company that makes battery smoke alarms, we're now one of the biggest intrusion alarm manufacturers in the EU region...
6K
Hi Everyone, What are your thoughts on adding a different make of battery back up mains powered smoke alarm?. The quick back story is that there...
I am in the process of getting my house rewired and I forget to think about adding smoke alarms and a burglar alarm. As the house is getting a...
4K
