P
pmosely
Visited a customer who has a domestic air conditioning unit with 13amp plug top. To connect to the socket she has to daisy chain into an extension lead as the A/C unit has been fitted at the top of the wall and the flex is to short to reach the socket and of course the lead dangles in the air! Yes I know, I thought that!
Trying to decide the best way to connect it - without moving the A/C unit.. Thought I'd use a fused connection unit - but, and it is a but, can I/should I spur (using a 2.5mm t&e) direct from double socket in the bedroom and into an FCU and then connect the A/C flex to it.
Or should I connect directly into the ring using JB (next to D/Socket) and then run a cable up the wall to an FCU, that will be next to and adjacent to the A/C and thus then connect the flex.
Concerns being can I cut the flex that has a moulded plug top and not breach any requirements?. The reason I ask is technically the first method I'm not certain its an ok way to do it and regs do not illustrate this method.
I am waiting for the manual to check load etc.. but at moment I'm assuming that the loading and diversity will all be ok.
Your thoughts thanks
Phil
Phil
