Discuss Air horn query. in the Auto Electrician Forum area at ElectriciansForums.net
Hi all.
I've always fitted a set of single tone air horns that I've swapped from car to car over the years, except, to my present motor, simply because the horn is very difficult to access. Anyway I arranged for my local garage to do the job & decided to make sure they were okay first, not having had them working for app 6years. Did the necessary with temp wiring etc & they didn't work? I removed the trumpet air linkage to the compressor & made a temporary connection from comp to the car battery. The comp ran but didn't sound as I'd expected it to. Hmmm! Now on the comp, the connections are clearly marked + pos & - neg which is naturally, how I've always wired them up using a relay & never had a problem. So I connected the wires again & put my finger over the comp outlet to the trumpets, it was "sucking" instead of blowing!!! As they've always worked when I've had them on my previous cars I was stunned. So because of the comp sucking, I reversed the polarity & it ran as it should.
So, neg on the comp to pos battery terminal, & pos on the comp to neg battery terminal. Test working fine, but how?
Thanks in anticipation.
Hi,could be faulty nomenclature,pipe on wrong outlet,marked up for positive ground fitment....how old is the set?
The unit is probably 15yrs old, but in retrospect hardly used. there's only the one outlet. I'll ring the garage tomorrow to explain & see what their lecky says. Each time I've fitted them, I've used the feed to the original horn as the relay feed. I'll post up what he says.
Reply to Air horn query. in the Auto Electrician Forum area at ElectriciansForums.net
Hi I’m stumped and can usually figure it out after a while but not on this one. so I joined here In search of some help on my 05 tundra I’m...
The air conditioning on my Vauxhall Astra J has stopped working and I'm running out of ideas on how to fix it. Steps so far: The compressor clutch...
I have a Security Light on my patio and until recently it worked fine. It stopped working and I couldn't decide if it was the LED Floodlight or...
Hi! Some help would be appreciated! I've just moved into new house, wanting to check insulation resestance etc as getting some nuisance...
I have a baffling problem with a newly-installed PIR floodlight and I'd like advice from the forum as to whether it's defective (and should be...
