Discuss Air Vent Removal (Electrical wires removed or capped?) in the UK Electrical Forum area at ElectriciansForums.net
Hi folks,
First post here and needing some help if that's ok?
I'm looking to remove an electric air vent from our downstairs toilet. The previous owners stated they used to have a shower in there, but this was removed by them and we have no need for one.
We are looking to renovate it though and as it's a bit of an eye-sore and lets in a lot of draft, I wanted to remove it. The vent is still hooked up to the electrics, although it doesn't actually work.
Upon removal of the vent, the wires are embedded in the wall and run across the window. I don't really want to pull the wites out of the wall as this will be a messy job if I can avoid it.
So, my question, is there a way that I can remove the vent and cap the wires off somehow before filling in the hole after removing the vent's fascia? Would I need a qualified sparky to do this or this a pretty easy fix?
I've included some pictures to hopefully give you a better idea of what I mean.
Appreciate any help on this.
Probably easier to just fit a new extractor.
cost ÂŁ12.00.
You cannot just cap off cables and leave them in wall. You will have to find the source and disconnect from there. It may be in a extractor isolator outside bathroom, or in a extractor pull cord or hard wired without means of isolation.
If it's the later it could be in the light switch, or the lamp, or in a junction box/wiring centre above cieling.
As I said probably easier to replace than remove.
The wiring - I assume - is buried in the wall. Runs over the window and then through the covering you can see into the extractor pull cord. Ideally, I'd like the whole thing to be removed, but again, trying to save a little on both the mess and the cost... but, then aren't we all. Interesting point about replacing it, might be best unless you think it can be removed?
Provided it can be safely isolated so that it can never become live ditch the supply and leave it in the wall. An electrician could do this in a short space of time.
Hi - I'd be upgrading the fan to one with built in draft excluder. Ventilation is good :) .
Definitely.
The term to look for when researching is a backdraught shutter. I live in a coastal location and try to persuade customers to go for fans with electronic backdraught shutters, the Airflow icon 15 is quite affordable and funky the way the shutters open and should be a straightfoward replacement
I don't think I've ever heard an extractor fan being called an electric air vent before! Will have to remember that. :)
Reply to Air Vent Removal (Electrical wires removed or capped?) in the UK Electrical Forum area at ElectriciansForums.net
My mate has family in Southern Ireland and he has been over there a couple of times this year helping them renovate a property. He has been...
HI There, I would be grateful if you could help me, I have a very long duct between the bathroom and extractor outlet vent and for sometime, the...
Hi all, Got an awkward bathroom fan installation in a downstairs flat, concrete ceilings and (some) walls. Bathroom is already fully tiled and...
I found myself needing to do some emergency plumbing at home this evening. I've got a small guest flat on my property which has been empty for...
Well....wiring in a 1750s thatched cottage attic, not wiring made from thatch 🤪 One we have been letting for over 20 years (as well as enjoying...
4K
