Discuss Alarm detector wiring in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
Y
YTSOxford
Hi all, started wiring an alarm today. its my first hardwired one, usually use the easy wirefree jobbies. Anyway is there common way that the conductors should be wired. IE, should the red be +ve and black -ve and the blue common etc. Its all working fine just worried about if anyone else was to come alaong.
Also some of the sensors will have to be linked between the zones. All of the cables go to the main control box. So if I loop the tamp and RELAY cores?
Hey Oxford.
I usually use the accenta range of alarm kit
The usual way I do it and have seen it done is-
Green+white = tamper circuit
Blue+yellow = zone circuit
Red+black = pos+neg
Yes all sensors can be linked together to create overlapping zones in the panel
Hope this helps.
Cheers.
Cheers, does indeed help. That arrangement makes sense. Im using the same brand, did think that linking would work but with the customer over your shoulder the whole time didn't want to try it till i was certain.
Thanks again
Reply to Alarm detector wiring in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
I'm trying to wire in a 4 core capacitive sensor into a safety circuit. I have brown, blue, white and black coloured cores and it's a NO sensor...
I have a baffling problem with a newly-installed PIR floodlight and I'd like advice from the forum as to whether it's defective (and should be...
Having a bit of a mare at the moment with a small 2 story HMO (6 single rooms with shared kitchen) which was fitted relatively recently (2016 or...
Hi, I'm replacing an old AT88A with the AT175F for my hydronic heating, which is connected to my 2-wire mercury t-stats and Honeywell V8043F zone...
Hi, I'm updating our bathroom and I'm changing our extractor fan from a simple ceiling mounted one to a more powerful inline version (Blauberg)...
6K
