Discuss Alarm system in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
Hi,
Customer bought an alarm system from toolstation and asked me to fit while wiring their garage/workshop. All fitted up etc but getting odd faults:
Low battery although tested and fine?
Zone 7 although only two pir's?
Bell box won't ring or sound?
Am I missing something or wiring incorrectly? Ever had any of these problems before.
Thanks!!
OK. is it a eurosec, by chance. if so, zone 7 is pre-programmed as panic. you can't delete it as not used. either re-program the zone 7 as 12 hour, then delete, or fit a link in the panel. low batt. could mean a blown fuse.
the gardtech panels have a mind of their own but once you're used to them, they're about the best value for the price. i love 'em. where else will you buy a full LCD keypad system for a similar price to a veritas or an accenta?
pm me if you need any more info. don't want too much detail on open forum.
Reply to Alarm system in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
Can someone please guide me on this? I have virtually no experience of home alarm systems. The client has an alarm which had been fitted to her...
Hi I’ve recently installed a texecom veritus excel alarm system but having an issue with the sounder not going off when triggered by the pir I’ve...
Hi. Not sure if it's the right place to ask, so won't be upset if it gets removed. Apologies if the terminology (PEN/PME/etc) is used...
6K
Hello, I would like to upgrade our existing, wired, burglar alarm system for smart alarm system. We don't use it as the cat keeps setting it off...
4K
Having a bit of a mare at the moment with a small 2 story HMO (6 single rooms with shared kitchen) which was fitted relatively recently (2016 or...
