Discuss Alarm systems types in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
brucey2343
Trainee
Hi all,
My boss has told me to set the system type of 2 smokes and a heat alarm as LD3+. Can anyone send me a link or reply with a description of what each grade of fire alarm system is? I always thought LD2 was smoke hall, smoke landing and heat alarm in kitchen, and LD3 was as above without the heat alarm
Cheers!
You have Grades of systems which refers to the detection type and this is combined with Category of system which is the level of protection.
Not wishing to hijack thread, but I can't figure out how to start a new one.
Can anyone tell me - is there a difference between an L1 fire alarm system and an L1 smoke alarm system?
I was talking to Aico a few weeks ago and I was telling them that when I worked for a house bashing contractor a few years ago the building regs only used to ask for smoke detectors in the escape routes ( LD3?)but the B.S of which the certificate is based upon require LD2 escape routes, kitchen (heat) and principle habitable rooms.
LD3 only covers circulation spaces/escape routes in a dwelling this would typically be hall, stairs and landing. LD2 is the same but includes specified rooms and areas deemed to be of a high fire risk.
Thanks, my memory was correct. I was trying to make the point that the building regs have still not caught up with the B.Standard.
Reply to Alarm systems types in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
Hi all, i'm just after a definitive answer regarding a fire alarm system in a communal area/stairwell. There are call points, smoke heads &...
I've asked a similar question before I think and we came to the conclusion that apart from new houses and HMO's etc there aren't any rules about...
I'm about to order this wired smoke alarm system as it can network but I just went to see how my existing fire alarms are hooked up and there...
I currently have a home with 7 interconnected, hard-wired smoke detectors. I have a hard-wired heat alarm in the garage that I need to have...
Here we go again, another job that has had a council inspection, different council to last time but still perplexing. The problem with these jobs...
