Discuss Alarm wiring in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
W
wallyanker
I am in need of some assistance with my house alarm. When I moved in 3 years ago the alarm was already in place but not working, no battery and fuse pulled out. I have replaced the battery, put the fuse in and am able to operate the alarm exept for one thing, the external bell box just won't be quiet!:confused: The only way to shut it up is to disconnect it from the control panel.
I thought it might be a tamper fault on the bell box so I linked it out on the control panel but that did work, so i now have another bell box. Please could you tell me what wires go where??
Control panel feeds bell box with 6 core, EXT +, EXT -, STR+, STR-, TR, SAB
Bell box has HOLD+, HOLD-, BELL, SET, STR, TR
Please help?
I cant help thinking the fuse was pulled and battery removed for a good reason (panel fault ?) I would buy a new panel (£35) and bell box and start again, you will then have the engineers code to set it up. Hope this helps
Please help?
is it a new romec bell you have? try ext+ to hold +,ext- to hold-,tr to tr,sab to bell,the str will be the strobe,depends if its +v to activate or 0v to activate try str- first if it flashes in unset mode swap to str +
Romec was Royal Mail Engineering, but is now a joint venture between Royal Mail and Balfour Beatty, the latter wearing the trousers in the house. Royal Mail Engineers now only maintain the sorting machines, Romec Engineers deal with the building engineering, ie electrical, plumbiing, heating and electronic security. Oh, and Post Boxes!!
qfa.tho depends if you have a royal mail contract or a balfour one,if you have a royal mail one(the one that is carved in stone) your sorted:)..cant see this marriage lasting tho:eek:
alarm man(ex romec) :)
Rememberthe alarm panel is essentially a battery charger there is 2 batteries in the system 1 in the panel the other in the sounder the panel battery needs to be replaced every 5 years. As for the sounder going off when you power the system up my question would be did you silence the clear any faults on the alarm panel. How is this done well if the cover is off exposing the tamper spring then power up the panel pres the spring you will hear a click then enter the user code then relese the spring and put the code back in this should silence the sounder but give you a tamper fault on the panel. If this happens replace the panel lid do not connect panel better back in the reset the system by entering the user code. Once clear check yo see if the systems sets and if so buy a new battery.
Reply to Alarm wiring in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
Can someone please guide me on this? I have virtually no experience of home alarm systems. The client has an alarm which had been fitted to her...
Daughter has bought a house and it has a home security system, G-Tag setup. Issue is the alarm panel displays are pixelated and you cant see...
Hi all Is it possible to connect a Texecom Odyssey 1E sounder to an Optima panel using 4 core cable and still allow the bell, strobe and tamper...
I’ve recently moved into a property with a Texecom premier elite system. I’ve been given the engineers code and have read up on the alarm. It...
Hi all, Requesting your help please! I know this is an old system but has been working amazingly for 7 years! I had an engineer out who done a...
