Discuss alarms , hard wired vs wireless in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
H
hadleigh sparks
I have been asked by a friend to install their alarm as they have been recently burgled. i have done a few over the last few years but to be honest i stray away from them as i prefer industrial and commercial wiring. I am NIC approved and cant be bothered to go down the nacoss route. but I will be putting my friends alarm in for their peace of mind.
my question is ( got their in the end) can i have all your opinions which is better , hard wired or wireless . what is the trade installing most of in current times.
cheers for your time
Hi,
I have been installing alarms for many years andf always have stuck to wired over wireless, but I must say the visonic range is excell
- - - Updated - - -
sorry guy dont know what happened there!!!!
As I was going to say
I am now hating my new PC, Must be female!!
As i was going to say
1 Easy to enroll detector,key fobs, bells etc
2 Can be brougt in a kit form 2 detectors 1 bell 1 control panel 2 key fobs already enrolled on system and this also includes a built in dialler
3 Fitting time should be no more than 3hrs including training of the customer
Brilliant thanks very much , sold on the wireless as their house is the most perfect with white carpets everwhere ( electricians nightmare ) will check out the visoninc range
We all have our preferences - I stick with Scantronic I-on for radio, but always prefer to instal wired if at all possible.
Regards.
Fitted the wireless scantronic I-on 16 to my own house 2 years ago as can't praise it enough
both have their advantages/disadvantages, wired is cheaper but it's got the wires that you need to hide. If cost isnt a major factor go for wireless. It costs about £100 to buy wired, £300 for wire free
When installing alarms, I always use wired systems.Texecom is my preferred make, who do offer some advanced wireless systems.I have added wireless devices to a wired system, and it has caused nothing but trouble for me. Receiver in loft, and detector in remote garage (no more than 20m away). The detector is often generating a system fault.
i use gardtec panels with wireless detectors from risco and have only ever had 1 problem with 1 installation being prone to crashing with a power cut. can be bought as a kit inc. 6 detectors for just over £200+ VAT.
wireless is very reliable now,for domestics id probably go wireless everytime customers prefer it to having boards lifted etc,id stick to wired for commercial ,are you getting radio faults or false alarms
I am assuming Radio faults.The log just says zone fault, with no clear indication of the cause.
I believe that the scant tonic I-on series do a system that is both wired and wireless, very handy if you want to upgrade an existing wired alarm with additional zones.
these wireless ones sound very impresive bet the alarm guys arent happy though less money for them with these
But they are generally quicker to fit! And for alarms, the revenue from annual servicing visits can be more important that the installation profit (though I appreciate that for many sparks it's the installation element that counts).
Regards
I've never fitted one (or even see one).
Is it just a case of running a mains supply to the panel then everthing else is wireless, keypad, bell, sensors etc?
At it's simplest, yes. Some systems still hard wire the RKP and/or external sounder, but often have wireless options. If you are going to install regularly, it's better to use one manufacturer and get to know the kit (and the quirks) well. Wireless has come a long way, but signal strength and interference are still issues to watch. Like all systems, getting to understand the programming and possible/likely source of faults is important too. Battery life has talen major steps forward over the last few years.
Regards
When I surfing I read information : Hardwired alarm panels are less expensive than wireless panels, but they are harder to install. Keep this in mind if you are planning on doing the installation yourself. An average home installation with a hard-wired system takes min 12-16 hours. A typical wireless installation will take less than 4 hours. The wireless system is helpful.
Reply to alarms , hard wired vs wireless in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
I currently have a home with 7 interconnected, hard-wired smoke detectors. I have a hard-wired heat alarm in the garage that I need to have...
I've asked a similar question before I think and we came to the conclusion that apart from new houses and HMO's etc there aren't any rules about...
Hello, I applied for a retrospective completion certificate for kitchen relocation. The work was done about 7 years ago. The building standard...
6K
Hello I’m a relatively new spark and have avoided installing wired security alarms instead opting for wireless systems for customers. I have a...
4K
Hi. I'm an I.T.. engineer with some outdated electrical experience. I qualified C&G 2330 17th edition about 15 years ago, but my only experience...
