Discuss all in one electrical wiring help in the Electrical Forum area at ElectriciansForums.net
Hi all,
I was wondering please if anyone could shed some light on how the electrics works for an all in one computer. For example a traditional desktop tower pc has it's own power supply unit and a plug into the wall, the monitor has the same and therefore two plugs into the wall are required.
However, with an all in one, both screen and computer hardware are powered by the same PSU.
Basically I'm looking at building a custom all in one solution and need to eliminate the need for two plugs off what is essentially one unit.
Any help given would be gratefully received.
Thank you
Steve
if it's an all in one, it will only need one flex (IEC lead) and thus only 1 plug.
Sorry to clarify, I want to build a custom unit but if I buy a touch screen it will require a power lead. The PSU for the pc hardware will require a power lead. I want to get the two of these working off one. Thank you
so splice then together in the plug.
Hi
Yes that's exactly what I am after. I didn't even know these things existed!I've seen extension leads with 4 gang / 8 gang etc but not these. That should work perfect.
Thank you both for your help :)
Steve
Hi
Steve
Glad to be of help.
I thought an 'all in one computer' was called a laptop. :)
Reply to all in one electrical wiring help in the Electrical Forum area at ElectriciansForums.net
