Discuss All RCBO board ..neat install in the UK Electrical Forum area at ElectriciansForums.net
Hello all,
Just wondering how you all go about making all RCBO boards look neat, tidy and professional when the extra neutral and functional earth flying leads are thrown in to the mix.
My plan is to run 100x50mm (still prefer to say 4x2) trunking along the bottom of the board with 25/32mm brass bushes through the knockouts and in to the trunking. Run all incoming cables up behind din rail and dress in to the RCBO. Don't really have a neat and tidy plan for the flying leads so thought I would ask the great and the good for advice/tips......
Thanks & ATB
Chris
Also depends on whether your consumer unit is a taller one designed for rcbos or bog standard designed for mcbs, so left with less room up top. Some also have the earth bar in the middle which can make it bit crowded. Thats my only gripe with the hager one.
I fitted one a customer got from denmans recently as she works as admin for them, so nice and cheap. surprisingly it was a doddle to install as its designed with rcbos in mind.
Use their compact RCBO's.
The board I am using is Niglon (I can hear the sharp intake of breath from here) the wholesaler we use through work had been knocking them out for 2 years and has had no bad reports so thought I would try it. First impressions are good, plenty of space up top for the Rcbo's and it feels like s solid unit.
All the knockouts are on 25mm centres from the back of the board so I reckon I will be ok with the trunking and 32mm bushes.
Will ferrule all the flying leads, my work is industrial maintenance and we use ferrules on everything.
Thanks for the advice so far.
ATB
Chris
I just installed a Hager Design 10. Not sure if I'll fit another. None of the fixings were keyhole ones, making it a bit of a nightmare when installing as a replacement, with existing cables in place. Main thing was the cost, haven't worked out my final price, but it was a fare bit more expensive than others.
Hagers compact RCBO's come without earth lead, but might give Wylex a bash next, with their new compact RCBO (as someone posted about recently), no earth lead & switched neutral.
I’m trying to ‘murdochise’ my way of installing advising RCBO boards.
I’ve taken to cutting and ferruling neutrals and earths and it looks neat. Someone on here had put a picture up of putting the CPC and the functional earth in the same hole on the earth bar and find that when all positioned on the same side of the CPC looks very smart! All I need to do now is start using 2mm earth sleeve instead of 3mm (shout out to Westward10!)
Cheers for all the input so far.
Had another look at the board this morning and have decided to take Leesparkykent's advice and have bought 75x75mm trunking instead, that should make fitting bushes and locknuts much easier.
I also bought a tail gland when I picked the board but I am now thinking of not using that in favour of bring the tails on through the trunking and one of the 32mm bushes knockouts on the bottom of the board. I think that will look better and save me drilling a 40mm hole in the top of the board.
ATB
Chris
If you use the double pole SBS/Luve boards you don’t have the problem if the neutral and fly leads, very tidy. Although I don’t like the Live metal boxes, they are fairly carp!
Reply to All RCBO board ..neat install in the UK Electrical Forum area at ElectriciansForums.net
I had a call to a new customer who was experiencing what sounded like nuisance tripping on a kitchen ring. Some background first. It's an MK LN...
Just carried out an EICR on a flat that was wired in the 70s - with singles run in earthed conduit to each point and the trunking providing the...
4K
Basic question to see if what I wish to do is correct: Client wants to build (or is building) and outside room (roughly 8m by 4m) to be used as a...
what do you guys do with yours? Currently on a job fitting a 24 way TP&N distribution board where all final circuits are going to be protected by...
