Discuss Alternatives to 10mm T&E in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Any know any good alternatives to 10mm T&E for a shower run?
cheers.
I use 10mm split concentric
not much difference in cost but the installing bit is FAR easier,smaller holes needed in joists,or can clip it outside (surface )as its UV protected.Clip it beside the drainpipe and no one notices it.It also comes with a full sized earth
Reply to Alternatives to 10mm T&E in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Client currently has a DB in his outhouse. It feeds a pool pump and an air source heat pump. It is currently being supplied using a 4mm T&E cable...
Seen a couple of videos with Doncaster cables now producuing a T&E with the CPC already sleeved so no need to fit our own. I also read somewhere...
I'm practising EICRs on friendly locations as I'm still in training - technically done my 2391-52 but frankly need loads more practise. I've just...
I have had my kitchen rewired and plastered. I have had a 6mm t+e on a dedicated 32a circuit for a 60cm electric cooker. In hindsight, had i known...
Good evening all, I’m currently part way through my apprenticeship and we are working on IB, IN, IZ and IT and volt drop today. And it got me...
