Discuss Am I liable to pay in the UK Electrical Forum area at ElectriciansForums.net
I rent a property in the UK. All of the sockets in my house were tripping, even when all sockets were switched off. An electrician came out, sent by the estate agent who manages the property. They determined it was an appliance of mine that tripped the power. He said something about why the socket was receiving power when the switch was off, but I'm not sure what it was he said as I am no electrician. Something to do with a neutral wire. I have received an invoice, from the estate agents, for me to pay the electrician as the fault was my appliance. I agree this would be my invoice to pay, however, I could have diagnosed the appliance as the fault myself had the landlords socket not been supplying power when switched off? Please could somebody advise me as to where I stand. Of course I am happy to pay if it is my responsibility. Thanks, Jean.
It could have been the faulty socket that damaged your appliance
It looks like the sockets in your rented property are single pole, so if the switch is off the neutral is still connected. The only way to be sure that the appliances in this instance are disconnected is to unplug everything.
What was it that was causing the problem?
The toaster. Is that a problem with the socket or an acceptable way for them to be?
Unfortunately,
most uk sockets only switch the live, the neutral remains connected to the appliance regardless of the switch position (on or off)
this might be a tough lesson to learn but if you are trying to diagnose if a fault is with the fixed wiring or an appliance then unplug evertyhing.
a short between neutral and earth will normally trip an rcd type breaker without any bang or flash.
so everything is now fine?
if you switch off the socket and plug the toaster in, I presume the electrics still trip off?
Sounds suspicious to me Jean, although unless the toaster is tested it's hard to be sure.
Has the tripping now stopped? If so, try the toaster again, if it still trips then it's the toaster so take it back. If it doesn't then it obviously wasn't the toaster.
Unfortunately,
Oops, I think I have an invoice to pay.
It is definitely the toaster. I thought the fact that it was tripping meant there was still power in the socket when switched off (which I would say is at the fault of the landlord). Another poster has pointed out that UK sockets tend to only switch the live and if there is a fault between neutral and earth then the RCD will trip. Looks like i'm at fault for my own incompetence
if you turn off that socket and plug the toaster in, does the electric trip off?
If you have rcds at home try the toaster there or another socket in the property. A toaster would be one of the last appliances I would suspect.
Reply to Am I liable to pay in the UK Electrical Forum area at ElectriciansForums.net
I'm not an electrician. I clean cookers and today arrived to a rangemaster range cooker. Got started, and as part of my routine, I turn on ovens...
Hello All, I am a homeowner (but not an electrician) and I am renovating a house that has an old CU containing MCBs and an MK LN5725 residual...
I'm unsure if I should be an electrician or maybe another trade is better. I have basically completed my first year of a foundation in...
Hello. we have had a few powercuts over past few months and am in middle of one at the moment where power has gone off a few times while DNO are...
4K
