Discuss AM2 question, need help in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Right, so I'm in the middle of my AM2 and I need to wire FP200 from the DB to a carbon monoxide alarm via multi compartment dado trunking, I've looked in the spec and it doesn't say anything about whether the FP needs to be separated from the T&E powering lights & sockets, can anyone give me an answer as to if I can put the FP in the compartment with the other power cables or does it need a separate compartment? I'd have thought that with FP carrying 230V and being screened then it would be fine but I don't want to fail over something as stupid as that.
Help appreciated.
Run it with your other circuits just use a different compartment for your data cable and don’t forget the separator when passes through the top compartment.
Holes will already be in place for glands etc.
On the AM2 FP is only used to supply a co2 detector to demonstrate termination only.
Reply to AM2 question, need help in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi fellow sparks, I've just started out on my own so I'm spending a lot of my time trying to find out the correct way of doing things of...
Hello I've been away from the industry for awhile and I've recently got back in to it again. I never finished off all my grades. I got both my...
Been round to a house to quote to replace some storage heaters for new panel heaters and came across a strange (to me at least) way of wiring the...
4K
This weekend I was replacing a hall light fixture in my old home (rewired circa 1980/90's) and noticed the work was done using one of the exposed...
