T
Tonydnb
Hi just found out a have failed my am2 on the installation section
Firstly I wondered if I can get any information on how I failed apart from them saying what circuits I failed on ( lighting/ bonding and swa to 16amp socket )
I thought I did all these correctly and can't see what I can fail on on the bonding as mine was all tight double checked all connections.
lighting circuit I used correct breaker, sleaving. All earths terminated, and functionally works- I did feed the light not the switch but can't see why that would be a problem
the socket was also wired all correctly . Phases labeled . Functionally works
any ideas what I could of failed on is it worth appealing for more information or them to re mark it ???
