Discuss Am2 in the Electrician Courses : Electrical Quals area at ElectriciansForums.net
Intermediate lighting circuit
wire a DOL starter to motor
s-plan heating system with solar
SY FLEX
SWA
ring final in singles with spur
CO2 detector wired in FP200 with switched spur (P clipped)
online exam
fault finding
inspection and test of your rig you installed
examiner will probably throw you some questions whilst testing
max zs values for certain breakers etc
no containment is needed to be installed. It's all there just needs wiring. Thinks that roughly everything I done mine couple years ago so can't remember too much
I would advise sitting the pre Am2 class, you basically do all of the above with plenty of time to practise and get it right before sitting your exam the next day. I went in blind the first time I done it and failed so be 100% sure you know how to do all of the above and the way they want it done and not yours. Good luck!
Thanks mate, did any of your nvq assessor come out to visit u guys out on work, because when I contact my assessor he says he well over worked and far to busy, so all I've been doing is jus taking picks of my work and coming close to the end of the course
Alright pal I did my NVQ with jtl they did come out to site but because were I work they couldn't actually see my work so just had to get a written letter of my company confirming what I written was a trueish account of the job lol.
Reply to Am2 in the Electrician Courses : Electrical Quals area at ElectriciansForums.net
Hi question whats my best route ive just done the am2 and past my nvq has expired as i took a while before completing the am2 i have level 2...
Hi all. I recently failed a section of my AM2E assessment. Passed 7/10 but failed on some silly things I'm confident of correcting second time...
Hi all, hoping for some advice, I’ve recent resit my AM2s after failing on first attempt… I’ve passed all my resit apart from section C just on...
Hi Guys I am currently on the NVQ 2357 on my way for the AM2 and get fully qualified, at the moment i am doing private jobs, on the NVQ 2357 they...
Good morning all, Got my AM2E coming up and wondered if anyone had any advice for the day? Also what order you thought best to do the...
