Discuss Amending a few PIR code 2's. in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
B
byrnie_2004
Hi all,
I've been asked to correct a few of the issues brought up by a recent PIR (the original contractor now has too much work on).
The building is fairly modern and the electrics not too old, the question I need to ask is:
One of the Code 2's that was brought up is - 3 gang switch fed by 3 separate circuits, can I pass this if i label the switch with a "multiple circuits" label or something of the sort?
(note 3 phase supply to the building & may have to label 415v if separate phases also.)
Cheers,
Dan.:mickey:
I would not code that a 2...if there is only 230v at the switch no code at all....if there is 400v a label should be provided,preferably at the switch but if this is not practical,at the CU.
That said the PIR is in place and you should rectify the defects listed....I would label at the CU something like you have suggested....include a 400v warning either at the switch or in your CU label if 400v is present at the switch.
Got to be honest I circuit label all switches/sockets i alter or install on any com/ind jobs, just looks better and yes and a 400v if req.
It only costs a dymo label and its done. on a large install it makes sence for anyone later to identify and sets you above the avarage spark who don't know better.
Cheers guys, I thought so. What would you code - "No RCD protection to socket circuits?
Bearing in mind its just a PIR no extra works are being done would that not be a code 4? - Doesn't comply to current regs
Its been brought up as a code 2, I'm not too sure (its a commercial property) offices etc.
I think you would need a 400V warning notice at the switch and any other enclosure where a voltage exceeding 230V is present and would not normally be expected
No code at all, unless any of the socket-outlets are used to supply mobile equipment outdoors.
If that is the case, then I would expect the observation to state such.
Reply to Amending a few PIR code 2's. in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Just bought an old house (about 30-40 years old) with a separate shop building. I am in the process of replacing old fluorescent fixtures with...
Recently visited a new build to do a very minor job and spotted a few dodgy looking items so Client asked me to do an EICR. Following items I...
I'm practising EICRs on friendly locations as I'm still in training - technically done my 2391-52 but frankly need loads more practise. I've just...
