Discuss American Electrical Problem in the UK Electrical Forum area at ElectriciansForums.net
Santa
I thought that some of you would find this amusing:
I'm remodelling my basement and replacing my electrical boxes and moving them out 1/2 inch for drywall.
The box that contains the main switch for the basement and the staircase gave us big shocks. I investigated and found a loose ground wire. When I reconnected the ground, the shocks stopped.
I still think that there is something wrong. I don't think there should be shocks even without a ground.
I have checked all the outlets connected to that circuit and I don't see any loose wires.
What could be wrong?
Switch box shocks badly. - Straight Dope Message Board - https://boards.straightdope.com/sdmb/showthread.php?t=856313
so if live wires are "hot" then what is the terminology in yankietown for a hot water pipe? im assuming a yank sparky would bond his hot wire to the hot pipe
but how would he get a wire nut on a pipe?
That whole thread seemed to just accept faults like that as normal and applying tape over screw terminals was a suitable solution. No mention of insulation testing the circuits. I have some American electrical books and the sections on testing is very limited, often stopping at a 'socket and see' type of check.
Reply to American Electrical Problem in the UK Electrical Forum area at ElectriciansForums.net
I experienced an electrical shock while replacing an A/C Fan Coil's 120vac, single phase motor that was above the ceiling grid in an office, while...
4K
Looking for counsel / guidance to replace an original Dayton On/off with speed control switch. I’ve checked with a couple local electrical supply...
DIYer here. I'd like to install an electric car wall charger myself. It calls for 6/2 romex which I have. Unfortunately my panel is in my...
Hello everyone In September 2023 I rented a beautiful 3 bedroom apartment, with all electric supply, no gas powered appliances. I noted down the...
