Discuss Amp buzzing Advice Please in the DIY Electrical Advice area at ElectriciansForums.net
hi,
After a bit of advice please.
Currently through my amplifier I am hearing a buzzing noise. I have told this is most probably a earthing problem. Can this be rectified easily? Can the one socket be fixed or does it need to be a whole re-wire.
I have tried different equipment and it still buzzes so it has to be something to do with the socket.
Thank you for any advice
There are lots of possible causes of buzz on audio systems, a fault on the power socket is actually one of the less likely ones. First, please can you confirm exactly what equipment you have heard the buzz on, what functions were in use (e.g playing CD player model x through integrated amp model x), and whether the buzz volume varied with the main volume control on the amp.
It's possible a capacitor has failed, or a solder joint has come loose. It could also be something called "ground loop" hum problem. If possible, please share more information to allow for more specific help. Like, what kind of amp do you have? What kind of instrument are you using with the amp? Are you using any pedals? Etc.
or try spraying with this:
:D:D:D
Reply to Amp buzzing Advice Please in the DIY Electrical Advice area at ElectriciansForums.net
Hi all I'm after some advice on 2 way CU in a garden office which is 'buzzing' when I turn on or increase the tempreture of the wall mounted...
Hi, I`m looking for an advice. I have an electric shower that I`m not using due to boiler changed to combi and added shower over bath feed by a...
Hi Looking for some advice please. Keep having issues with flickering lights, some devices such as dehumidifier "stuttering" because power...
Hi Everyone, This is my last question/post for tonight, promise. Please can I ask for a little advice on certificates as I am now questioning...
Completed my AM2s start of this year. My whole career plan is to run my own company/sole trader. Be my own boss basically. I always get asked...
