Discuss Amtech modelling question in the UK Electrical Forum area at ElectriciansForums.net
Lc1
We have 2 MCCBs feeding a busbar chamber. There is then three separate supplies taken out of the chamber to feed other equipment. Does anyone know how to model this scenario on Amtech?
You can actually model busbars and tap offs, but not for the application of a busbar chamber. The most accurate way to represent it is a switchboard. A switchboard is essentially a busbar chamber.
Reply to Amtech modelling question in the UK Electrical Forum area at ElectriciansForums.net
Hi guys, With regards to modelling a multi service distribution board, how would you guys model it in Amtech? I have tried using a TPN...
4K
Incoming supply on our job comes into the building and then the tails from which go into a switched isolator with 200A fuses fitted. No idea...
On an EICR I found a 200 amp 3ph supply, TNS earthing (which looks original) and Ze of 19 ohms. No rods. No RCDs. L1 -> N was about 0.5 ohms...
We are looking for a distribution board to provide 3 * 160A three-phase feeds, but they are basically redundant supply path options so max total...
Good morning all, I am currently working on a House in Multiple Occupation (HMO) consisting of 10 flats, with three parking spots equipped with...
