Discuss an on going arguement in the Canada area at ElectriciansForums.net
P
pfc0397
i have an on going arguement at the moment and i don't know who to listen to,
before you make an addition to a circuit does it need testing? is it just the circuit or the whole installtion that needs testing?
If your doing an addition to the circuit i.e extra sockets on the ring or any works that does'nt involve a new circuit back to the board then you are supposed to fill out a minor works form. This would require a r1+r2, Zs and insulation resistance for the circuit you are working on only. Plus RCD operating times its a circuit that requires one.
BEFORE you add on ,in a perfect world, you would need the previous results otherwise how would you know if you're going over the max zs,or the ir is satifactory?if you add on without this info and theres a problem how do you know where the fault lies? as your the last to touch it, its yours to put right
of course if you're confident of the existing circuit ....go ahead
Reply to an on going arguement in the Canada area at ElectriciansForums.net
We are a UK registered Electrical company with a large contract based in and around Toronto, Canada. Are you looking for work? We have a...
Completed my AM2s start of this year. My whole career plan is to run my own company/sole trader. Be my own boss basically. I always get asked...
Just thinking about selling MFT's and single test equipment. The idea being I buy stuff from Ebay and sell it on ebay, which I am doing at the...
Been asked to move, remove and add some sockets the kitchen and I’ll need to add a circuit for an electric hob. Looked at the board and it’s one...
My friend just moved into a new build flat and its for a disabled person with a hydraulic lift to go to the upper floor. There was/is a leak...
