Discuss Analogue Dashboard in the Auto Electrician Forum area at ElectriciansForums.net
T
trailerman
Is there anyone on here able to build me a custom clock set up for my project as its past my capabilities as I dont want a fire best consult an expert, hence why Im asking on here ! Thanks :punk:
My fault for not explaining correctly !
I mean gauges and warning lights rev counter ! its for my project but using all mechanical old skool for a straight 6 diesel mechanical , no ECU
Im not sure Im reading the question right here..
you want to UPSCALE 12v (Volts) to 24v .. if so then NO.
If its 24v to 12v then i guess you could use a Potentional Divider, two Resisters or same value in series.
most vehicles work on 5v dash panels right back to the 70`s, using a voltage reg.....fuel, temp, rev, and indication. Add on clocks such as smiths etc, will be set at 12v for simple installation reasons. But fuel & indication are set on 5v......We need more info, 12v to 24v is possible but more complex, 24v to 12v & 5v is very simple, with regulation. I`ve designed a lot of digital dashes for boats and racing cars, If we get the full spec, I maybe able to draw something up for you.
GREAT ! I really do need help ! Im stuck ............I will post a pic of what I need later today and I will show what I need it for ,and thanks for your time ;)
Problem with the daf dash is that its only part of the system, the ecu controls display and other sensor, you could strip unit down to basic speedometer, rev counter, fuel and temp, but the displays will need external custom cpu made, expensive.
You still haven`t explained car you modifying, engine size, fuel etc
I am using the engine too ! but it has no ECU so dont think its driven by one ! Im busy putting engine into Transit van
Ok where getting somewhere....so its a Ford Transit van, what year?.....and daf engine diesel or petrol ? and size of engine?
Tazz ! thanks for your input ! great having an expert keep you right ;)
The van is 54 plate, the engine is Cummins 6bt 5.9L turbo intercooler !
Ive been trying to upload a few pics but Im just not good enough
Anything else feel free to ask ;)
Hi,as it happens,i know the LF very well,and its' many electronic problems...that dash interacts with the ECU,and would be very tricky to bypass,and ensure all the clocks functioned.
A good place to start,would be what senders/sensors have you? I'm guessing the Cummins will have its' own temp(s),oil pressure,alternator tacho feed etc,and the transit will have the original fuel tank sender?
...You could always stick a 2 litre V-4 back in it....worked in the 70's :clap:
Hi its not the LF its the FA ! NO ECU like I said !
All the senders are original DAF 24v ones !
Hi fella,that dash board you linked to,has fault code and info panels,that means ECU interaction...
Luckily for you,the B series cummins has been in production for years,from 130 to 180+hp,and this means its' various tapped ports,will accept all manner of senders,meaning a simpler way round would be to use an older,say Roadrunner dashboard.
The later Paccar series engines,have all manner of troublesome electronic issues,which are depressing,knowing just how good these engines are...
Have you got access to the dashboard from the engine donor vehicle? ...Without the standard vehicle system in place,you would have to assess each individual guage input requirement,and maybe separate, items "dualled up" within the dash-pod,obviously leaving code and error fault capability,out of it.
Thanks for reply ! yes your right that dash is out the paccar one but only used that for reference sorry ,the one I want to use is very similar only no digital screen ,my fault for using that pic when I should have got the right one, I scrapped the truck I took engine and box out of so I need to get a set of clocks just wanted to know if I could graft them in ;)
Reply to Analogue Dashboard in the Auto Electrician Forum area at ElectriciansForums.net
Hello ! I am building for some time a cct to drive a 3digit multiplexed LCD. (from aliexpress) From the sellers on aliexpress I managed to find...
Hi fellow sparks, I've just started out on my own so I'm spending a lot of my time trying to find out the correct way of doing things of...
Hi All, Not sure if this is the best place to post but here goes! I'm over 50 and not working at the moment (semi retired) but I'd like to get...
