Discuss annoying IR fault in the UK Electrical Forum area at ElectriciansForums.net
G
gavin.sibley
Had an IR fault on a newly installed lighting circuit today, 0.00ohms with continuity of 0.37 between neutral and earth, split the circuit down and down again until I find which room it's in, full of spotlights, keep splitting until I narrow it down to the last spot, disconnect spot fault clears, spent over an hour splitting it down and taking it all apart to get this far only too find the lamp holder has slipped out of position and an metal screw has managed to jam itself in the neutral side of the holder, damn that was annoying being something so stupid! Then had too spend ages putting it all back together again -_-
Lol, look on the bright side, work is work and I assume your time was chargeable.
Unfortunately not, I installed the thing and was just commissioning/testing :(
Its almost always the last thing you look at, the last half of a half of a half, and its always something stupid.
but finding it is a winner.
Reply to annoying IR fault in the UK Electrical Forum area at ElectriciansForums.net
A silly fault in a circuit only 4m long is currently eluding me! This is ECIR remedials of a landlords supply in a block of flats. Circuit 2 =...
Hi was recently at a property and was installing a Solar PV system. was doing my testing and i came across a weird result when doing the...
Recently changed a CU for a friend and today when visiting one of the RFC's RCBOs tripped. It was due attention anyway as open ring and no time to...
I have a baffling problem with a newly-installed PIR floodlight and I'd like advice from the forum as to whether it's defective (and should be...
