Discuss Annual visual inspection in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
DHES
Hi all
My company has been asked to carry out annual visual inspections In between periodics in a number of schools in the borough has anybody got any info on this or a spread sheet if possible that you have found helpful/useful
We have to look at each room to see if there are any problems.
The first draft we had a separate sheet for each room but this gets a bit much when it comes to a large secondary school with about 300 rooms and 40 odd distribution boards.
Any info would be good
there are pir visual test sheets available niceic ones or ones you can down load a visual inspection is exactly as it says pad in hand and right down any cracked broken overheating etc of any electrical devices incluiding all containment
Reply to Annual visual inspection in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Hi all, first post so go easy! This is for people who are looking for more info on the course and exams and is from my experience of doing the...
  • Locked
5K
I installed outdoor lighting and outlets. I finished this past year. I passed my inspection on April 2022. I was so pleased, BUT now the circuit...
I quite often contribute on other's posts about issues with RCD's, thought I'd tell you about what happened to me yesterday as a little bit of a...
